Overview
About Advantech Container Catalog (ACC)
Advantech Container Catalog is a comprehensive collection of ready-to-use, containerized software packages designed to accelerate the development and deployment of Edge AI applications. By offering pre-integrated solutions optimized for embedded hardware, it simplifies the challenges often faced with software and hardware compatibility, especially in GPU/NPU-accelerated environments.
Key benefits of the Container Catalog include:
| Feature / Benefit | Description |
| Accelerated Edge AI Development | Ready-to-use containerized solutions for fast prototyping and deployment |
| Hardware Compatibility Solved | Eliminates embedded hardware and AI software package incompatibility |
| GPU/NPU Access Ready | Supports passthrough for efficient hardware acceleration |
| Model Conversion & Optimization | Built-in AI model quantization and format conversion support |
| Optimized for CV & LLM Applications | Pre-optimized containers for computer vision and large language models |
| Scalable Device Management | Supports large-scale IoT deployments via WEDA, Kubernetes, etc. |
| Lower Entry Barrier for Developers | High-level language (Python, C#, etc.) support enables easier development |
| Developer Accessibility | Junior engineers can build embedded AI applications more easily |
| Increased Customer Stickiness | Simplified tools lead to higher adoption and retention |
| Open Ecosystem | 3rd-party developers can integrate new apps to expand the platform |
Container Overview
Intel iGPU OpenVINO Object Detection is a Retinopathy detection demo Container on Intel 12&13th Gen CPU and iGPU.
Using the integrated GPU (iGPU) in Intel 12th and 13th Gen Core processors, developers can efficiently run AI workloads like diabetic retinopathy detection directly on compact edge systems. These iGPUs support Intel® OpenVINO™ Toolkit, enabling optimized inference for deep learning models without requiring a discrete GPU. With improved parallel computing performance and low power consumption, the Intel iGPU is well-suited for AI-powered medical imaging applications where space, energy efficiency, and cost are critical. By leveraging Intel’s platform, healthcare developers can deploy accurate and responsive diabetic retinopathy detection models in clinics or point-of-care devices, making AI-assisted diagnostics more accessible and scalable.
Key Features
- AI Application Demo: Retinopathy detection
- Hardware Acceleration: Optimized access to CPU, iGPU.
- Complete AI Framework Stack: OpenVINO
- Industrial Vision Support: Accelerated OpenCV
- Edge AI Capabilities: Support for computer vision
Host Device Prerequisites
Hardware Specifications
| Component | Specification |
| Target Hardware | ARK-3534 |
| CPU | 12th&13th Gen Intel® i3/i5/i7/i9 |
| iGPU | Intel UHD Graphics 770 |
| Memory | 16 ~ 64 GB shared CPU memory |
Prerequisite Software on Host OS
| Component | Version | Description |
| intel gpu driver | 24.26.30049.6 |
Container Environment Overview
Software Components
| OpenVINO Runtime | 2023.1.0.12185 | OpenVINO Runtime provides AI framework run Model inference, and deploy applications |
| OpenCV | 4.7.0 | Computer vision library |
| YOLO | X | YOLOX Computer Vision Model for Retinopathy detection |
| Retinopathy detection | 1.0.0 | Retinopathy detection AI Demo |
Quick Start Guide
Refer to Advantech Container Catalog Github: ACC-L3-01-Qualocmm-AI-enabled-Container and Intel Gen 12th~13th Edge AI Container for more quick start guide details.
Run on CPU
sudo docker run -it --privileged=true --ipc host --device /dev/dri:/dev/dri --device-cgroup-rule='c 189:* rmw' -v /tmp/.X11-unix:/tmp/.X11-unix -v /dev/bus/usb:/dev/bus/usb -u root --env DISPLAY=:0 --rm eiot/eas-intel-1213-retinopathy-demo:ubuntu22.04-1.0.0 /bin/bash -c "~/omz_demos_build/intel64/Release/object_detection_demo -i /opt/intel/openvino/Eye/object_detection/video/output_4288_2848_FPS=1.mp4 -m /opt/intel/openvino/Eye/object_detection/model-test/last_epoch_ckpt-opset-10.xml -at yolox -output_resolution 1280x720 -t 0.9 -labels "/opt/intel/openvino_2023.0.1.11005/Eye/Eye.labels"" -loop -d CPU
Copyright © Advantech Corporation. All rights reserved.
