Catalog
Overview
About Advantech Container Catalog (ACC)
Advantech Container Catalog is a comprehensive collection of ready-to-use, containerized software packages designed to accelerate the development and deployment of Edge AI applications. By offering pre-integrated solutions optimized for embedded hardware, ACC simplifies the challenge of software-hardware compatibility, especially in GPU/NPU-accelerated environments.
Feature / Benefit Description
Accelerated Edge AI Development Ready-to-use containerized solutions for faster prototyping and deployment
Hardware Compatible Eliminates embedded hardware and software package incompatibility
GPU/NPU Access Ready Supports passthrough for efficient hardware acceleration
Model Conversion & Optimization Built-in AI model quantization and format conversion support
Optimized for CV & LLM Applications Pre-optimized containers for computer vision and large language models
Container Overview
This container, GPU Passthrough on NVIDIA Jetson™, provides a ready-to-use environment with optimized AI frameworks, GPU passthrough, and industrial-grade reliability on NVIDIA Jetson™ platforms. It enables users to focus on developing AI applications on Advantech Edge AI systems accelerated by NVIDIA chipsets—eliminating the complexity of hardware setup and AI framework compatibility.
Key Features
  • Full Hardware Acceleration: Optimized access to GPU, NVENC/NVDEC, and DLA
  • Complete AI Framework Stack: PyTorch, TensorFlow, ONNX Runtime, and TensorRT™
  • Industrial Vision Support: Accelerated OpenCV and GStreamer pipelines
  • Edge AI Capabilities: Support for computer vision, LLMs, and time-series analysis
  • Performance Optimized: Tuned specifically for Advantech EPC-R7300 and more devices
Host Device Prerequisites
Item Specification
Compatible Hardware Advantech devices accelerated by NVIDIA Jetson™ - refer to Compatible hardware
NVIDIA Jetson™ Version 5. x
Host OS Ubuntu 20.04
Required Software packages *refer to below
Software Installation NVIDIA Jetson™ Software Package Installation
Required Software Packages on Host Device
These packages are bound with NVIDIA Jetson™ version of the device. This container supports NVIDIA Jetson™ 5.x.
Component Version Description
CUDA® Toolkit 11.4.315 GPU computing platform
cuDNN 8.6.0.166 Deep Neural Network library
TensorRT™ 8.5.2.2 Inference optimizer and runtime
VPI 2.2.7 or above
Vulkan 1.3.204 or above
OpenCV 4.5.4 with CUDA®: NO
Container Environment Overview
Software Components on Container Image
CUDA® 11.4.315 GPU computing platform
cuDNN 8.6.0 Deep Neural Network library
PyTorch 2.0.0+nv23.02 Deep learning framework
TensorFlow 2.12.0+nv23.05 Machine learning framework
ONNX Runtime 1.16.3 Cross-platform inference engine
OpenCV 4.5.0 Computer vision library with CUDA®
GStreamer 1.16.2 Multimedia framework
Container Quick Start Guide
For container quick start, including docker-compose file, and more, please refer to Advantech Container Repository
Supported AI Capabilities
Vision Models
Model Family Versions Performance (FPS) Quantization Support
YOLO v3/v4/v5 (up to v5.6.0), v6 (up to v6.2), v7 (up to v7.0), v8 (up to v8.0) YOLOv5s: 45-60 @ 640x640, YOLOv8n: 40-55 @ 640x640, YOLOv8s: 30-40 @ 640x640 INT8, FP16, FP32
SSD MobileNetV1/V2 SSD, EfficientDet-D0/D1 MobileNetV2 SSD: 50-65 @ 300x300, EfficientDet-D0: 25-35 @ 512x512 INT8, FP16, FP32
Faster R-CNN ResNet50/ResNet101 backbones ResNet50: 3-5 @ 1024x1024 FP16, FP32
Segmentation DeepLabV3+, UNet DeepLabV3+ (MobileNetV2): 12-20 @ 512x512 INT8, FP16, FP32
Classification ResNet (18/50), MobileNet (V1/V2/V3), EfficientNet (B0-B2) ResNet18: 120-150 @ 224x224, MobileNetV2: 180-210 @ 224x224 INT8, FP16, FP32
Pose Estimation PoseNet, HRNet (up to W18) PoseNet: 15-25 @ 256x256 FP16, FP32
Language Models Recommendation
Model Family Versions Memory Requirements Performance Notes
DeepSeek Coder Mini (1.3B), Light (1.5B) 2-3 GB 10-15 tokens/sec in FP16
TinyLlama 1.1B 2 GB 8-12 tokens/sec in FP16
Phi Phi-1.5 (1.3B), Phi-2 (2.7B) 1.5-3 GB Phi-1.5: 8-12 tokens/sec in FP16, Phi-2: 4-8 tokens/sec in FP16
Llama 2 7B (Quantized to 4-bit) 3-4 GB 1-2 tokens/sec in INT4/INT8
Mistral 7B (Quantized to 4-bit) 3-4 GB 1-2 tokens/sec in INT4/INT8
DeepSeek R1 1.5B Optimizations Recommendations:
  • Supports INT4-8 quantization for inference
  • Best performance with TensorRT™ engine conversion
  • Typical throughput: 8-12 tokens/sec in FP16, 12-18 tokens/sec in INT8
  • Recommended batch size: 1-2 for real-time applications
Supported AI Model Formats
Format Support Level Compatible Versions Notes
ONNX Full 1.10.0 - 1.16.3 Recommended for cross-framework compatibility
TensorRT™ Full 7.x - 8.5.x Best for performance-critical applications
PyTorch (JIT) Full 1.8.0 - 2.0.0 Native support via TorchScript
TensorFlow SavedModel Full 2.8.0 - 2.12.0 Recommended TF deployment format
TFLite Partial Up to 2.12.0 May have limited hardware acceleration
Hardware Acceleration Support
Accelerator Support Level Compatible Libraries Notes
CUDA® Full PyTorch, TensorFlow, OpenCV, ONNX Runtime Primary acceleration method
TensorRT™ Full ONNX, TensorFlow, PyTorch (via export) Recommended for inference optimization
cuDNN Full PyTorch, TensorFlow Accelerates deep learning primitives
NVDEC Full GStreamer, FFmpeg Hardware video decoding
NVENC Full GStreamer, FFmpeg Hardware video encoding
DLA Partial TensorRT™ Requires specific model optimization
Copyright © Advantech Corporation. All rights reserved.
